300/440/550 PJS Lazerjet F-14 build
Hi guys, I picked up this ski the other day and im in need of some advice and parts where possible. It has a broken steering cable and a crappy flywheel. What sort of steering cable works with this? 650sx?? and does anyone have a total loss system or a charging flywheel for a 550. Any help would be greatly appreciated.DSC_0137.jpg
If my brain serves me right the steering cable is the same from a 650sx. The flywheel will be tricky because these skis came factory with a total loss ignition system. therefore if you are having problems getting the ski to run make SURE the battery is fully charged. If you cannot find a flywheel anywhere i may be willing to part with a jetnetics TL flywheel i have.
Aquaholic
World's Oldest Teenager
San Diego, CA.
Bzzzzzzzzzzzzzzzt...wrong. Those abominations had standard OEM charging electrics.
What that POS did come stock with, however, was a built in extraction device, that would automatically suck $$$ out of your wallet.
waxhead
wannabe backflipper
gold coast
I wasnt sure if they had a charging system or not. They had the solar panel in the handle pole to charge which I thought was a cool idea.
I pulled the steering cable off an old 650sx hull I had and it works perfect. Now the big problem is flywheel and electrics. I cant seem to be able to find a Complete total loss system for this thing, just bits and pieces at this stage. Im basically starting a fresh with this motor, the guy I bought it off had it completely disassembled so I think ill find some missing bits as I go unfortunately.
