Fancy fate
Can't have anything nice.
- se michigan
Where can I get oem starter rebuild kits? Got 2 I'd like to rebuild.
@JetManiac carry them?
I got a aftermarket that came in a box of parts and 2 oems. I'm gonna a open them and compare. The aftermarket has and always will be a paper weight lol.The front bearing is a special one. I was able to source a couple. Koyo made it special for mitsuba. I’ve re built a couple for some local guys. Maybe I should put together kits if people would be interested.
I have pulled some aftermarket Ones apart and they use a bushing front and rear.I got a aftermarket that came in a box of parts and 2 oems. I'm gonna a open them and compare. The aftermarket has and always will be a paper weight lol.
This^^You can do a bushing. Works fine
Caltric kits are fine. Work well. Cheap
You can also type Mitsuba sm13 into eBay and buy a used one from a motorcycle. Swap the rear off your current starter. And have a oem low hour starter that has most likely never seen water. For cheaper than a rebuild kit.
Sent from my SM-G970U using Tapatalk
When yaw do rebuild them, do yaw put any grease on the bushing in the back cap, shaft and washers that are internal to the starter? If so what kind?
I make the starter as clean as possible. For me. That means no grease, lube, oil, nothin.Anyone?
How did you order them? I need some.The front bearing is a special one. I was able to source a couple. Koyo made it special for mitsuba. I’ve re built a couple for some local guys. Maybe I should put together kits if people would be interested.
I’m interested if you still have that part number. ThanksI found a brush kit in Honda part # cheap and oem quality , # are out in garage , I'll share if anyone is interested just message me
Jason
