waterfreak
I had a vision!
- s florida
Here's the problem:
Symptom - Deposit on piston skirts.
Cause - Piston rings worn past the maximum ring end gap spec, glazed cylinder walls.
Reason - This is the most common problem we see. If the rings are worn past the maximum specification they allow combustion chamber gases to seep past the rings and down the piston skirt causing a distinct deposit pattern.
If the cylinder walls are glazed or too far worn the same thing will happen and even fitting new rings will not provide a good enough seal. In this instance the oil glazing must be removed and the cylinder re-honed to restore its cross-hatching, thus enabling new rings to wear to the cylinder and make a good seal.
