Tyler Zane
Open Your Eyes
- Panama City Beach, FL
I'm at work and a buddy has a pile of bulk plug wire he wants to sell. Can someone measure the outside diameter of a coil wire for me, this stuff is 8mm.
8mm works but you have to bore out the stock hole to accept it since stock is only 7mm. Not a problem since you have to build a boring tool anyways so just build it to work with 8mm wires.
FYI, I still use the old school solid core type with tinned copper wires. Some say it causes interference, my experience has been otherwise.
Maybe some setups are more sensitive than others and require the extra shielding of spiral core wires but you will also find a whole bunch of these "finicky" systems out there running perfectly fine with solid core wires.
Some wires are just built better than others so I would do the research and see what the general consensus is on the wire in question.
If it's a decent deal, just get it, try it out and report back to us.![]()
This is how I have been connecting to the pin.View attachment 342137
Yes, I do. Wouldn't want to give the wire an excuse to slip out of the coil tower.So do you still epoxy the insulation into the coil?
