Motorheads5
Livin the generation gap
- ketchikan alaska
Is the Octane crankshaft tapered on the drive coupler end ?We have built a polaris base snowmobile engine and need to build or find a drive coupling to match a kawasaki x-2 driveshaft. I was wondering if the Octane crank is the same crank used in the liberty 800 motor's and if maybe I can use a set of Octane coulper's ?I will also try and call Randy at Watcon but wondering if one of you guy's might know Thank's.
