Super Jet Ocean-Pro DL150 nozzle help. What is this outlet?
sharkcus
Breakin' the atmosphere.
Strongsville, OH
I recently decided I wanted to go dual cooling. Then I noticed on the "bilge suction" side of the nozzle, there is a place to hook up a water line. It doesn't appear to be drilled through, so I would have to do that. But I'm not sure what it does. If it's for dual cooling, why is facing backward? I hope its not for a bilge.
This is the side with the stock cooling line (I use this to run through-hull:
This is the "bilge suction" side. If I can't use that fitting on the nozzle, where do I tap?
Another angle of the "bilge side"
DirtyJ
Freedom aint free no more
Its on the other side of your pump. I believe you may have a Waveblaster or couch reduction nozzle and that fitting is for your visibility spout. Plug it up and your good to go.
sharkcus
Strongsville, OH
That's what I thought too. It is plugged, I don't think it was ever drilled out.
So that being said, where do I tap for dual cooling then? I don't see anywhere else on that side to tap.
sharkcus
Strongsville, OH
Oh crap. Wait. I'm confused. Is the one on the nozzle for the bilge? am I thinking backwards? Looking at the back of the ski, is the bilge on the right and the cooling on the left?
Okay yeah, I was mixed up. I'll tap the round thing like everyone else. I was just curious about the nozzle and you guys answered my question. Thanks!!
DirtyJ
Its on the other side of the pump Bro. There is a casting that sticks out shaped like a cylinder, thats where you have to drill the fitting. You use your old bilge line and the stock cooling line. In the end there will be a line on each side.
