sharkcus
Breakin' the atmosphere.
- Strongsville, OH
I recently decided I wanted to go dual cooling. Then I noticed on the "bilge suction" side of the nozzle, there is a place to hook up a water line. It doesn't appear to be drilled through, so I would have to do that. But I'm not sure what it does. If it's for dual cooling, why is facing backward? I hope its not for a bilge.
This is the side with the stock cooling line (I use this to run through-hull:
This is the "bilge suction" side. If I can't use that fitting on the nozzle, where do I tap?
Another angle of the "bilge side"
