not one but all four!!!
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Its all west marine had. West Marine sucks ass too!
Im going to cut that tube in small pieces, but it in a drum and light it on fire with a gallon of gas. Yea something has to burn!!
FYI: you can find fast cure at Academy (Sports & Outdoors), it's in the boating section
QuickMick
API 1104 AWS CWI
Started foaming tonight, did both sides of the tray behind the footholds!:arms::arms:
Then ran out of foam :Banane36:
I found some two part foam here in my area, will finish foaming tomorrow.:bananajump:
QuickMick
API 1104 AWS CWI
you should really get someone that is qualified to do this for you.
Just tell me what time your flight gets in to Hobby and I can pick you up.
You see my pics, im not qualified.
You should of been there when I mixed up my first batch of foam. measure, mix, stir like a sombitch for 30 seconds then pour........ nothing.....nothing.........nothing. Im thinking, when does the volcano reaction start to kick in?
Then I got it down pat. measure, mix stir for one minute watching the second hand on the wall clock, then pour. Im still wondering, where is the 15 X expansion? I dont see it.
None the less Im pretty sure there are no voids in my pours, as Moonunit and I tilted, rotated and moved that ski in every direction to work all the voids out.
Moonie's going to get to do the motor install :headbang: and detail electrical work while Im finishing up glassing the top of the tray.
QuickMick
API 1104 AWS CWI
Foam is DONE!! Thanks AJ and Wavechaser for the foam hookup!! WOOT WOOT!:headbang:
Moonunit did a good job sanding down the foam nice and even so the top piece can be glassed in.
Wondering if I should glass in a piece of mat over the whole foam right before I glass in the top piece in? Would that help or is it not needed??
