not one but all four!!!
QuickMick
API 1104 AWS CWI
Damn! Nice job guys! Turf looks great!
Why 2 fuel filters... just curious
Thanks!!
Because THATS HOW THE HOOTER SCOOTER ROLLS!!!
Thats how it was when the ski was transplanted to Texas. One filter per carb may be a lil overkill? Not sure, I just added the second filter bracket to clean up the hull.
I have seen some of the Green hulk guys run a filter for each carb and one in each return line, oh and lawn sprinkler filters in their water injection lines. WOW
Waiting on mid shaft bearings, HS has a lil noise coming from the midshaft. Which should of been checked 2 months ago so the parts would be here today! But NNNNNnnnNNNNNNOOOoooo I never thought to check the midshaft bearing. Yea now im waiting on parts as usuall!:frown:
If she breaks this hull, Im going to put up a second mortgage on my house and get her a Trinity hull. not
QuickMick
API 1104 AWS CWI
Nice Work that look's really good. Did you use raider mount's?
Thanks, Naww 4 OEM mounts. Not sure why, but the shimming spacing is way different than the old ones. Im using about twice the shims on all 4 as what I removed. Had to replace the motor side of the coupler also. I found a crack in it.
QuickMick
API 1104 AWS CWI
I seem to remember she's got 44's in there, not 38's.
Don't they have their own feeds from the tank?
Correct
Possible, all depends on how its set up....makes about the only sense for having 2 filters though
I'm a little shocked there are no pictures of the needed shimming though :biggrin:
Will post tonight. DOCUMENTATION my boy! Had to order a few .010 shims of MMC, and some cool shiney rub rail bolts.
QuickMick
API 1104 AWS CWI
She's jackin around instead of fixing her ski.
