New Rickter Ski?
What carbon hulls are there for $7.5k plus?
Trinity? I would guess the quality is substantially better.
XFT? Same guess, but I don't know.
Lightweight.de - quite a bit more expensive, but by far the best quality I've ever seen
Germany
Compare it to the new LIGHT WEIGHT ski which you will find at the WF BLOWSION stand.
THE ONE which is great for Freestyle and Surf.
Shark,
You need to sell me one REALLY cheap or better yet just give me full sponsorship. That way I can get one of those hulls around to a bunch of freerides and try to sell some for you!
Germany
Here the infos from WakeUp race performance:
RICKTER X-FS
The latest development out of the Rickter serial: The new X-FS.
Finally this is the back flip specialized Jetski from Rick Roy. It is very short, very light, with an 8 " set back and enlarged pump area in order to keep the water flow powerfull as long as possible during set up of a back flip.
This hull really helps you a lot performing you 1st back flip and if you just are able to do 1, it will help you to master 2 or 3 or more. As this hull is very specialized it is the wrong hull for old school tricks or free riding.
STAGE I - Hull only
Comes complete with hood, pole bracket, mat set and adjustable foot holds. 100% compatible with Yamaha technique.
US$ 6.500,- in Fiber VOB Bangkok or € 5.825,- excl. VAT VOB Austria
US$ 9.500,- in Carbon VOB Bangkok or € 8.290,- excl. VAT VOB Austria
US$ 10.800,- in Carbon / Kevlar VOB Bangkok or € 9.290,- excl. VAT VOB Austria
STAGE II - Complete engine, ready to build in.
8 mm or 12 mm stroker engine with billet power valve cylinder & ported crankcase, incl. carbs, manifold, reeds, flywheel, dry-pipe.€ 9.350,-(8 mm) excl. VAT VOB Austria
€13.990,-(12mm) excl. VAT VOB Austria
STAGE III
Equipped with 950 ccm, or 1000 ccm stroker engine, Billet power valve cylinder, billet crank case, adjustable Rick Roy handle pole, steering and bar, Magnum Pump, Power Factor pipe, freestyle fuel cell, etc Depending on compression and ignition up to 220 HP The Bun 1000 ccm engine is used by the 2008 Freestyle World champion Fumikazu Watanabe and the Amateur World champion 2009, Manabu Matsubayashi.
€ 29.200,- (8mm), 33.400,-(12mm) excl. VAT in Fiber VOB Austria
€ 31.700,- (8mm), 35.900,-(12mm) excl. VAT in Carbon VOB Austria
€ 32.700,- (8mm), 36.900,-(12mm) excl. VAT in Carbon / Kevlar VOB Austria
see post #33 for more pics
ahh, i forgot you have to have a login to our forum :banghead:
here you go
Aircraftsalz
Thrust built Dasa Power
Off site
Any idea on weight?
The problem with the current FS1/FS2 is weight, heavy for the money compared to other hulls.
I like the new design, much needed to make the Rickter a flatwater ski.
That is just awesome. These newest pics are NOT the same ski in the original video posted. The ski in the video looks just like a shortened Rickter, but these pics show some pretty cool modifications.
Aaron
