New product -- pole mounts
snowxr
V watch your daughters V
Waterford, MI
Ok guys, on the SN conversion. If I get about 5 guys to place orders, I'll make a bracket JUST for the SN conversion. The holes will all line up for a direct bolt on, but you'll have to move your hood side hooks. Easy, right?.
If I don't get 5 to commit I'll offer the RN bracket with different stops, to allow more pole movement. You'll have to drill new mounting holes in your hull, as well as figuring out where you're putting your hood hooks or brap strap.
snowxr
Waterford, MI
SN conversion bracket
Here's how the SN specific bracket will look. The design work is done, so I'm just waiting on orders before producing them. It will retain the stock SN backing plate and needs no hull grinding. new hood hook location is built in. $130 shipped
snowxr
Waterford, MI
I may be down for one of the SN w/ RN pole mounting, just a couple of questions.
Is it stock height or lowered?
Do the hood hooks line up now?
Thanks,
Luke
The bracket mounts the RN pole at about the same level as a SN pole sits. There's no way to make it lower without a lot of fiberglass work.
You will need to move the hood hooks. The SN hooks will bolt to my bracket.
snowxr
Waterford, MI
If you wanted to know you could have just sent me a PM. I don't read every single post on X every single day. It's roughly 3/4" fwd. if you order that option.
