new light weight flywheel superjet
cambo au
TRYING TO LEARN
AUSTRALIA
i have a mate that makes titanium center flywheels for F1 mecury outboards and aftershowing him a rad one i had here he is going to start making a prototype one for a 701 he maks two types one with a spring steel center and another with a titanium center i will post a picture of the ones he makes the 701 will be similar in design let me know some feed back on what you think
What is the weight of the 2 mercury flywheels. And what about cost est? If the cost is down there they will sell like hot cakes even if the weight savings is minimal.
cambo au
TRYING TO LEARN
AUSTRALIA
i will have to find out what the merc ones weigh but they are a bigger wheel as for cost we will have to make one first to see that but imo it should be better as it has a flex plate witch will help with any vibrations
SUPERTUNE
Race Gas Rules
Clearwater Fl.
If your going to that amount of work on building a modern flywheel...he needs to work on adding a digital pick-up boss on the outside of flywheel and bracket assembly to mount a coil pickup in cases to upgrade the the very bad designed stock Yamaha pulser pickup design! Like a more modern digtial ignitions that Kawasaki or Seadoo ignitions that come stock on them...This would now set him apart for all the rest! Goodbye MSD Enhancers, goodbye Advents, goodbye Vilders and goodbye Wax Racing, it would kill all them cdi boxes!!!!
Now welcome to the new digital computer ignitions of today! This is what we need not just another fancy stock working flywheel.
waxhead
wannabe backflipper
gold coast
I agree supertune
if yamaha came out with the 760 electronics on there 701 it would be great
I dont know if it would be goodbye it would be just reinvent
infact it would be so close to an sxr ignition system it would be easy to make
But in the meantime these flywheels would be interesting and i would be interested in one
njfl
X-H2
Aluminum is lighter than Titanium. If you look at the lightweight ones we have available today and you change to titanium, the weight will only go up, unless he can make it significantly thinner. Right?
#ZERO
Beach Bum
Florida - U.S.A.
I think you're right and with all those allen bolts that would be just another problem waiting to happen.
cambo au
TRYING TO LEARN
AUSTRALIA
they spin a f1 merc to 11000 rpm witch is more than a superjet will ever see and as far as i know they have not had any let go yet
as far as digital gos can we incorperate this in to the flywheel that works with a standard elec box?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I would not think that an outboard would get anywhere near the shockloads of a PWC crank or flywheel though.
wouldnt the 90 degree direction change and gear reduction in the lower unit dampen alot of those loads? not to mention the long twisty driveshaft from the engine?
the flywheels look cool, the larger merc flywheels ive messed with were HEAVY stockers.
waxhead
wannabe backflipper
gold coast
you would have to put a lump on the inside of the flywheel to make a pickup work and then get a sensor that will replace the pulse sensor
you could then take theexciter coil out and just run the charge system
the cdi could run off the battery only
this setup would make for a very reliable cdi system because it had a reasonably constant power source
sjetrider
Aluminum is lighter than Titanium but it can be made much thinner especially if the p/u ran on outside like a 760 flywheel. A combo would be ideal, like ring gear and center from Titanium but the body in billet alum, is this poss?
EDIT: Never mind. Your edit makes sense.
