it opens up the ex. port wider. when its closed you get lowend power, and when the engine reaches a certain rpm, the valve opens. giving it high speed power too.
ADA is selling there Billet cylinder & head for $1495. Not sure how much it cost to get the sleves installed & port work. But it seems like a good deal.
You could always send the 38's you have out to Art at Jetworks and let him mod them for you. I'd probably go ahead and find a nice used set of 44's though.
Your cylinder needs to be cut to make good power. After that make sure the pump is not overloading the engine and you will need to raise the rev limit a little. Dont bother with carbs yet, at least not until you have learned how to tune your stock ones. Bigger carbs will wake up the pipe but wont make much more power.
