- Oak Forest, Illinois
Let me first start off saying i searched and didnt find anything what i wanted to do :-(
This is my delema. I broke my SN pole, so i got a RN bracket and pole. when i mounted the bracket i just redrilled the holes and stuck the bracket on. It looked good. but when i put on the pole. it seemed very low. It won't go its maximum height. and i figured out why. the bracket is on an angel. so i did this. to make it level. VERY GHETTO.
just added some plastic to the bottom to make the bracket level. now im not that good in grinding or Welding.
yamanube seen what i did and he mentoned that what i did creates pressure points on the hull, and can make the hull crack ALOT easier.
so he put out this simple, generan drawing for me.
his drawing tells me to gring down some of the bracket to make it on an angel with the hull.
and i have neard that some people used glass to make it level on the hull itself. like the RN bracket area.
What would be the easiest way to do this??
PLease help a fellow rider out.
Thanks Guys!
Thanks Guys!
