Went riding 2 weeks ago, ran great with zero problems. Got home, pulled off the hood and let it sit. Went to the lake the next week to find a no fire-no spark problem. Full charge on the battery, good clean connections around, good fuse, good brain box (jetinetics TL ignition). I ohmed the plug wires and they seem to be good, checked all grounds and they are good so I tried doing some testing on the coil. The one lead that is "always on" has 12 volts going into the coil, the other lead "signal lead" also seems to have 12 volts constant even with the ignition turned off. So I pulled the lead off to find slight power going into the ring terminal on the lead when the ignition is on but even when disconnected from the system the "signal" terminal on the coil has a constant 12 volts coming out of it. Does this mean my coil is fried and the power and signal coils are fused running constant power throughout or should the signal terminal always have power coming from it?
