got a ported(unknown) 61x cyl(81.5m bore) with broken off exh studs and two helicoils so, i got 83mm pistons and dropped the cyl off today at powerseal usa. a local cyl repair shop. they are going to bore and hone to 83m bore and drill and tap the exh to 62t thread size. my current setup is a std bore t/t motor with ada girdled head running 35cc domes. i forgot to measure the exhaust ports but my question is what should i do with the domes? what is a good compression to run? send them to zero or buy 760 domes? i think i want the compression to be just under the acceptable limit of pump gas (93 octane) also how will this effect my carb tuning?
preemptively, thank you guys
andy
andy
