Freestyle Need advice on impeller..
My SXR has the following mods:
-Lightened flywheel
-Wet Pipe
-Advent ignition
-Bored nozzle
-Flow control valve
-Dual cooling
My stock impeller is bent and i am looking to finally change it out. What do you guys suggest for the most bottom end? I ride flat water/rec.
Thanks,
Jordan
Octane_114
LeT tHe gOOd tImEs RoLL
Charleston S.C.
-Lightened flywheel
-Wet Pipe
-Advent ignition
-Bored nozzle
-Flow control valve
-Dual cooling
Thanks,
Jordan
i would call impross. your body weight and the way you ride (position in the tray) has a lot to do with impellers and the angle/pitch which you select. i run a c75 13/18 on 1 x2 and a a hooker 10/18 another. wife's sxr is a dynafly 11/19. the sxr has your upgrades plus more. dynafly is lightest and since you are running the tbm flywheel you mine as well take the weight off the other end too. i'd step up and buy the dynafly impeller and a r&d or tbm pump stuffer. both well worth the money!
