cmeripper26
Ripper26
- Connecticut
If you have a good tester you can check the resistance in the coil wires you are using now to see if the numbers match up. The numbers are in the Kawi SXR manual.
My JSS wires only lasted one year and they were toast.
Coils typically do not go bad and if they do they fire or they don't. wires on the other hand need to be replaced from time to time. I have run my MSD coil for about 7 years with 2 sets of wires. John's wires are very good, it took me quite some time searching on the internet to find the multi strand wire that he uses. IMO
Mark44
You can get Belden Wire from NAPA 7mm and 8mm
All I know is that with both JSS wired coils my ski acted up. Put the resistor boot plugs on and all was well again. Doesn't make much sense to me.
Is it multistrand or solid core I don't like solid core on a ski it breaks down fast from vibration but multistrand lasts a very long time. Taylor makes a very nice multistrand.... I hate to give up all my insider information.
Mark44
yup, it is the same stuff JSS uses. Believe he contacted Belden and got them to imprint JSS on the wires. Or he found a different supplier, but it is the same stuff. he started out using "Belden" wire. I have a coil that I redid in 2002 that still works with the NAPA wire.
