My Gpr
RDH
HEAVY WATER
blew up last fall and i overhauled the whole ********!n thing this winter spring.....
2000 gp1200r....set up for offshore
rius billett o-ring heads
pro-x pistons
trued and welded CW crank
RPM bearing crank snout/flywheel support
vf3's reeds
pro-tec stuffers
double fuel pick-up//removed trap door
re-jetted//removed acc pump/choke plates
pre-mix//removed oil pump
dual cooling
jetworks mod
factory triple pipes
advent t3 ignition
riva gas valves
free flow exhaust
1200 grate
jims ff modded R&D plate
blueprinted shoe
protec nozzle
AAT pump cone
solas 14/20 sb
pump tunnel reinforced
updated with 2005 inserts
all new bearings/seals
all new drive shafts
jettrim seat cover
pro-taper contour carmichael bars//with stock qsts
tag grips
tiny tach
primer kit
500gph w/switch ...kept stock bilge
garmin 60csx
thats all that comes to my head now.... this list changes from time to time...
Y
yamaslut
Guest
I still have my GPR, lots of mods and it wasn't all that slow. :cool2:
Now she's just covered in dust while I have fun on my old square.
:splatt:
I wanna ride that bitch...
I rode a 15F the other weekend.... that bitch was bad ass and all stock...
I forgot how fast those things (sitdowns) are
