Update..
I took the ski out on Saturday and still has the problem..
First I tried a different sparkplug. I tried BR7HS since someone told me the ski might be running too cool. But that didn't work out. It overheated my engine and the sensor kicked in. So i switched back to the br8hs.
I did switched over to Klotz high performance 2 cycle oil. This made a pretty noticable difference on the engine. It just felt better and i like the scent ha I will post a pic tomorrow when I remove the plugs to compare the oils.
I was using Royal Purple and that left a lot of resin on the plugs, so lets see..
I'm thinking my problem might be somewhere in my carbs...
Source for the following texts "
http://www.factorypipe.com/t_carbtuning.php"
While reading the article a few things caught my attention..
1."Remember, the low speed adjuster is only for adjusting the idle mixture. If you use the adjuster to help get rid of a low speed hesitation, you will probably find that your engine will load up in no wake zones, or after extended idling.".
I am pretty sure this is is happening also..
2."An indication that your pop-off needs to be adjusted is a lean hesitation when you open the throttle from idle; in the extreme, the engine may even die. It is much easier to detect a lean pop-off than it is a rich one, so it is wise to adjust your pop-off until you get it too lean and then back up until the lean hesitation disappears."
3."Fuel Dripping From The Inner Venturi At Idle
This situation occurs periodically and is easy to cure. What causes this problem is a combination of two things. First, low pop-off pressure (due to installation of a 2.5 needle valve with a light spring pressure) together with an engine that has substantial vibration at idle. The engine vibration causes the needle valve to leak, which causes the engine to run even rougher. You can view this occurrence by carefully looking into the throat of the carb at idle, you will be able to see fuel dripping from the inner venturi. In this same way you can also check to see that the problem is corrected. The cure for the problem is to increase pop-off pressure until the dripping stops."
Hopefully someone can tell me if i'm on the right track. This weekend my goal is to retune my carbs + B-pipe the way it states on the website. Basically following these instructions step by step.
http://www.factorypipe.com/t_carbtuning.php +
http://www.factorypipe.com/t_pipetuning.php
One thing I forgot to mention was everytime it bogged if I leaned the ski to the left making the exhaust stick out of the water and i rev it it cleared up a lot quicker.
Is it my carbs or my pipe? either way I am retuning both just to make sure
