SXR-FOREVER
Finally Flippin
- Lake Minnetonka, MN
The plan is to drop it down from 371lbs to around 330 ready to run.
Mods that I have done:
-4cm setback motor
-TDR Waterbox
-Footholds
-UMI pole w/ cotter pin
-R&D Head
-VFII's
-JSU Spacers
-Fly Arrestors w/adaptors
-Wetpipe
-Advent ignition
-Solas 13-22 cutback
-Jetdynamics intake grate
-D-cut ride plate
-Too much heavy blowsion bling
-C.A.T.S. using an X2 nozzle
Mods for the winter will be (as long as there is money):
Setback pump 4 cm
Shorten hull by 50mm/2 inches or so
Remove rear exhaust
Porting
Flywheel
Lose the heavy blowsion bling
9lb battery
Trinity Composite goodies
Carbon chin pad
Dual Oneways
Paint (hopefully)
Returf
Whatever else I want to do
-4cm setback motor
-TDR Waterbox
-Footholds
-R&D Head
-VFII's
-JSU Spacers
-Wetpipe
-Advent ignition
-D-cut ride plate
Setback pump 4 cm
Remove rear exhaust
Porting
Flywheel
9lb battery
Carbon chin pad
Dual Oneways
Paint (hopefully)
Returf
