waxhead
wannabe backflipper
- gold coast
the gain from a total loss system is the adjustablity of the ignition curve as well as the light weight flywheel
bigger spark will not help you unless you are having trouble firing your plug
once you have lit your fuel you cant light it again
And if you are concerned about not having your plugs firing then index them and that will no longer be an issue
