Mondo build. Done
Resmondo
Blood Sweat & Gearz
Pcola
So didnt have to cut it out….probably a stupid mistake but I think i still saved a lot of work in the long run. Glassing it back in and getting it lined up right was easy enough. Just screwed the pump shoe flush and it made the fitment easy back in.
Resmondo
Blood Sweat & Gearz
Pcola
When i measured the other
pump tunnel dimensionally it was the same size as my 144 tunnel. Width and length were the same. The height was slightly different is some spots but not worth it seeing how easy this is to glass the back and grind out the water side.
Resmondo
Blood Sweat & Gearz
Pcola
Got the nose faired out and looking decent i think. Gonna use the primer as a good guide coat and maybe fair one more time. Also working on a 750 550 swap. Got the 750 running great yesterday.
Resmondo
Blood Sweat & Gearz
Pcola
exhaust, cooling x2, bilge, trim, and steering in today. All 1/2 pex. Stock steering tube.
Resmondo
Blood Sweat & Gearz
Pcola
Foamed and glassed 1 layer
Resmondo
Blood Sweat & Gearz
Pcola
Setting up the footholds and then ill foam and glass around them and be done.
Sanoman
AbouttoKrash
NE Tenn
lf you need any more foam l have about 2/3 of a 4lb kit.Just opened a couple weeks back.Been in the fridge keeping it fresh!
Resmondo
Blood Sweat & Gearz
Pcola
I was actually about to order some more. If you really dont need it, ill gladly pay you for it. I think im going to scrape out under the footholds and put some denser stuff where I’d stand and land. Ive been using 2lb and it works good under the big areas and sides.
Resmondo
Blood Sweat & Gearz
Pcola
Got some foaming done. 6lb under footholds. That stuff is like concrete and 2lb in rails/sides. Gonna start shaping and then glassing it up
Resmondo
Blood Sweat & Gearz
Pcola
Added some more foam where my shins would be…..i think the right spot anyway. Left the back end of them slim. Putting down two layers of 7.5 oz cloth. Maybe do a few more in the corners. Then ill even the floor out and bevel it and lay another layer of the combo cloth and tie it all together.
Resmondo
Blood Sweat & Gearz
Pcola
Resmondo
Blood Sweat & Gearz
Pcola
Where does one find the cable organizer/ tie points for a superjet? The ones that rivet under the hood seal? Most of mine were broken and im gonna be reinforcing all that hood area. My friend found a crack all the way through.
Resmondo
Blood Sweat & Gearz
Pcola
Almost done with glassin! Got the deck set with 2 more layers of 7.5 oz glass then one layer of epoxy over top as it was drying to smooth it out. About 3 layers 7.5 oz in the bottom of hull where the rocker piece met the original hull. I had to sand a lot away from the bottom to get it fair, so i added a few layers inside. Then down the sides two layers of 7.5 oz and lots of 404 in the big gaps. Turning out pretty good i do believe.
Resmondo
Blood Sweat & Gearz
Pcola
What yall think about chiquita banana yellow? I have a black pole and pissers and all all. Wanted to do white on the bottom with yellow on top.
Resmondo
Blood Sweat & Gearz
Pcola
Can anyone tell me how wide the intake grates are for like rickter hulls? Like the worx 242 grate? I opened my pump tunnel up by at least an 1 1/2 inch.
Not OEM or anything but this is what I am using in my EME. I tried it with the included "self adhesive" but it didn't hold up at all on carbon. I ended up removing the adhesive completely (down to bare plastic) then I drilled another two holes to match the two already there to help with bonding (may not be necessary but i figured what the hell). Then i used g flex to adhere them to the inside of the hull where i needed them.
