- South Florida
Yeah I used pvc for the trim and steering tube too. I was referring to the cooling lines in my previous posts.
It's this one. It got buried in all the other fx1 builds. No one was interested. https://www.x-h2o.com/threads/5-wdk-f1pro.201728/@hornedogg79 that is clean work. Is that white pvc tube on the right side of your photo a drain tube for a scupper valve? And what ski is that? Is it a flat / no sidewall deck? A photo of the completed ski would be appreciated with Resmondo's permission of course.
I sealed the brass fittings to the hull with 5200. I drill the hole to fit tightly around the fitting so the nut doesn't slip through. When the pex is clamped on it's mechanically attached to the hull. The grommet provided with my thrust trim fits 1/2".Yea so with 1/2” pex for your trim, whatd you seal your tube with? @hornedogg79
