press the shaft out towards the coupling... then take a seal puller and pull out the oil seals, make sure you take note of their rotational position because you need to reinstall the new ones in the same order... then get an internal snap ring tool and pull out the snap rings, then press out the bearing...
thanks to jrmagoos
