My midshaft housing took a dump on my Superjet SN so I replaced it and also replaced the midshaft itself. All new bearings and seals and also I put on new couplers. The issue is the midshaft has some side to side movement. If I hold the housing in my right hand and grab the midshaft with my left hand it moves around a bit. I am guessing the single bearing has a little bit of play in it. Should I be concerned or just run it? Thanks!
