Quinc
Buy a Superjet
- California
Been working on the blaster all summer getting it running and now I am working to see how far I can push it. Figured I would document changes and modifications here.
Any input or suggestion are more then welcome! (Not looking to put in a triple.) If anyone is breaking the 50mph mark with a 61x or 62t engine please post what you have done.:bananalama:
06/02/2018 - Faster then a spark.
62t/61x 754cc - Freestyle ported by CPT
Dual 38's Vortex flame arrestors
Boyesen Rad Valves
TNT chamber 2mm stinger water spraying from top screw only
14.5/18 Solas
53.2MPH@6750rpms 04/24/14
New setup Changes:
701cc - Freestyle ported by CPT
44mm sbn
ocean pro flame arrestor
Ada head 37cc
Stock cdi
Coffman Rocket exhaust (Cleaned inside and out like new with no carbon.)
Port matched and polished exhaust manifold
New Solas I 14.5/18
Blueprinted pump
46.8mph @7300 Dec 17 2013
718cc 61x/61x
Ported and polished ( I think race ported) has a 318 engraved on the side of the cylinder if that means anything to anyone.
91 octane
TDR waterbox
Protec head
Protec 46mm carb H165 L125 2.3 N/S. Not sure what spring.
Stock Reeds
Ocean Pro Flame Arrestor.
MSD Enhancer set to 8000
Stock prop
OP Ride plate
OP Intake grate
49.3mph @6870rpms ( And A-LOT more bottom end )
Switched Pro-tec head to an ADA girdled 35cc w/ new BR8ES Spark plugs
Matched exhaust gasket to cylinder
Ground the exhaust manifold to match the gasket
Polished the exhaust manifold starting at 80grit down to red rouge polish
Cleaned all of the carbon out of the pipe with simple green, wire brush and 100grit
Turned the main jet all the way out and she still wanted more.
Next on the list of mods, plan is to do one at a time and re-test rpms and top speed.
Boyesen Rad Valves
14.5/18 Solas
New setup Changes:
44mm sbn
Ada head 37cc
Stock cdi
New Solas I 14.5/18
Blueprinted pump
718cc 61x/61x
91 octane
TDR waterbox
Protec head
Stock Reeds
Stock prop
OP Ride plate
OP Intake grate
