you also need a big hub prop to run a mag pump either a 08 up superjet stock impeller or a hooker would be my prop of choice my setup is almost exactly the same as yours.
JM is asking that most likely because if there is a gap you are losing power. If there is a gap you will want a new wear ring when you get the pump and prop.
If there is a larger than normal gap, then the impeller is worn and inefficient. A new impeller will be a bigger benefit in this case. Wear rings dont usually 'wear' much, the impeller does.
its a 91 square with 61x61x 701 msd enhancer protec pipe d cut plate etc, dropped in a solas mag and a hooker and could feel a big difference on bottom end especially in chop.
