Other limited chambers no more....?
Tyler Zane
Open Your Eyes
i was just talking to Art yesterday and he said factory pipe in no longer making limited chambers. anyone know more about this?
he said the mod chamber will work out great tuned properly....?
SJBrit
Extraordinary Alien
Bradenton, FL
Well then my B-Pipe just got a whole lot more valuable! Art certainly does turn out a great motor using a mod pipe, but lots of people use a limited for low end.
Big Kahuna
Administrator
Tuscaloosa, AL
I talked to someone years ago at FPP when I was first looking for a pipe. The guy there told me to go with the Mod Chamber. I ended up getting a Limited Chamber at the time, switched to a Speedwerx and then ordered a new Mod Pipe. I installed the Mod Chamber on a bone stock cylinder with the single carb conversion. I could honestly barely tell a difference, it did not have as quick a hit off the bottom but the power in the mid was stronger.
You can also use your adjustment screws to help tune the pipe to make it act more like a longer chamber.
Tyler Zane
Open Your Eyes
good to hear, also my mag pump is going to be set up with the mod chamber in mind.
Fl
I have a Xscream stinger tweek limmited chammber that I'll sell for $1,000,000. (insert Dr Evil laugh)
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Funny, cause my roommate just bought a brand new limited pipe from Factory Pipe. He asked if they were going to stop making the limited chamber and Cindy was like "Nope, and I'll send you one today"
Check your facts....
waxhead
wannabe backflipper
gold coast
I would never run a mod on a customers boat out of choice. If they come to me with that then I will run it. the power is much more abrupt in the surf and it doesn't respond to small throttle inputs like a limited
I would have though fp would stop selling the mod before the limited
227
Its all about the surf!
Oceanside, CA
I have 2 SJ's which are both set up Identicle engine wise (all stock with B pipes) EXCEPT one has a limited chamber and the other has a mod chamber and honestly I can't tell the difference performance wise. I CAN tell a big difference when removing/installing. The mod chamber comes right out but with the Limited chamber I invent new cuss words every time I have to pull/reinstall it because its such a pain in the a$$. IMO I'd go with a Mod chamber if I were buying another even if the Limited was available
maybe they meant to say they stopped making them until the next production run?
