lamey cylinder
78mm stroke.... Thanks for the info Virgin+Hunter...
I know for the surf I will stick with the 701 based motor... less weight, and you dont need the crazy power.
I could definetly see that motor making some Big HP #'s! Just havnt heard much real world sucsess about them.
Hell my 780cc flattop motor will rip your freggin hands off!
Sorry for the thread jack.
THRUST
ThrustInnovations.com
yea at the moment it is still a little exotic . at the fact you cant just bolt in and go plus you are starting over a bit at configuring your hull internally . but guys are getting 400 plus hours if the valves dont fail on sitdown applications and i would say for the most part they are in the upper rpm range alot more than we are on a stand up .
I would call it exotic only because you need a specialty hull to bolt it into....
couldnt you just run waveeater clips (same as GPR's) for reliability?
