im willing to put it on another scale, just need to find one. ill check it again tomorrow with a different one. what lb. foam? stock hull? thats what my stock hull weighed reinforced.
I put mostly extruded polystyrene foam in my ski - doesn't absorb water and quite a bit lighter than even 2lb foam.
There's about 1/4 vol of 3lb foam in there, too.
The bilge is reinforced with one layer carbon/kevlar, one layer carbon, one layer carbon/kevlar, no excess resin. Nothing on the bottom.
The back has the sides reinforced with mat/weave glass and a pretty good portion of resin.
Stock exhaust tube, blowsion one way and pvc pipe.
Back has 2 inches cut off.
And that's it.
I checked with a second scale today and came to 118-120lbs, so that's pretty consistent with the other scale.
I would be ecstatic if your hull really weighs in at 88lbs, but knowing what exactly is on my hull, I have a hard time picturing a 34lbs difference anywhere. :dunno:
