SX/SXi/SXi Pro Just picked up a PRO.
Boris
The Good Old Days
From what I have read so far, the Pro had the motor moved forward a bit.
Don't know yet if it was done by using a different bed plate or if the motor mount locations were moved.
sxi steve
Life's short, have fun.
Clinton Twp, MI
Once you pipe it, call Dave at Impros for a suggestion on a prop. People are gonna tell you to junk the handlepole, but if you are just going to run buoys
you'll be fine, once you get used to the weight of the pole. Get the head milled if you want to bump compression a bit without spending too much $$. A decent grate (top loader type) and a Worx Dominator plate(extended) will help keep the nose down, as Pros are really prone to porpoising.
I miss the handling aspects of my Kawi, if I ran across a deal I'd pick one up as a 3rd standup.
I love my sxi-pro..., I did the above bold (and more), that's good advise. I think for the $60, the timing advance plate made a good improvement in low end pop. It's an easy job, especially if you have the motor out. I did mine with the motor in the boat. Note- I believe I have the Skat Trak 9-17 Big Hub impeller, per Dave's advise.
Boris
The Good Old Days
If I open up the front, how can I tell the timing hasn't been messed with already ?
Right now the motor if drying (fresh paint all over) but should be dry soon.
My plan is to have it in the water by the weekend (as long as I can get the needed gaskets by then) and than once it warms up some, I'll stick the wife on the boat. If she likes it than it will stay mostly stock.
sxi steve
Clinton Twp, MI
Your's most likely all stock. There is a square timing component attached to the inside of the flywheel cover this is the component that is relocated a few degrees, i believe clockwise, per the plate which is sandwich between the two. I hope this makes some sort of sence.
Boris
The Good Old Days
the grabber green engine paint is available at carquest or napa.
That Grabber Green isn't a perfect match for stock but it sure does look better. Day-Glo 80's are in force.
BTW, picked up the only 2 cans Napa had and the third I scored from AutoZone. It's a RUST-OLEUM engine enamel and is a perfect match for the DUPLICOLOR stuff.
Boris
The Good Old Days
Got the motor all nice and purdy, cleaned up the bilge to like new, cleaned out the gas tank,.................................
Time to assemble, right ?
Wrong.
The water box is swiss cheese.
Shait.
Seams that Kawasaki and Yamaha have something in common. Both think that stickers over holes in the bulkhead will keep the foam dry.
Lucky mine is but what a stupid idea.
X2Pilot
X2 v2.0
Sin City USA
SX
overall length 2210mm
overall width 700mm
overall height 680mm
dry weight 144kg (317lbs)
SXi
overall width 700mm
dry weight 155kg (341lbs)
SXR
overall length 2300mm (90.55in)
overall width 730mm (28.7in)
overall height 735mm (28.9in)
dry weight 159kg (351lbs)
