oxnard111
Creative RE Purchasing
- so Cali, Ventura/Oxnard area
Since removing the stock choke plates when I installed a primer kit I have read that sometimes it is best to just leave the plates in, but its too late for that now.
I have a 62T case 61x cylinder stock engine in a 93 SN
Everything is stock including FA's and pipe with the exception of a stock WB1 impeller and modified stock CDI.
Dual stock 38's.
Just wondering if I should be using stock jetting or what would be needed? I have stock jetting in there now, but can't seem to get rid of bottom end lean condition. When you nail the throttle it does well on accelerating, but when you let off the throttle from a WOT run, then grab another handful of throttle it leans out and sometimes dies.
What jetting and how many turns on each mixture screw? Thanks!
Dual stock 38's.
