Jetting Dual 44's help.
Mahopac, NY
I have similiar setup but with a ported cylinder. I run 130 lows, 110 highs, 2.3 needle with 20 psi pop off.
So I would guess around 125 lows, 105 highs, pop off around 20 -25 psi.
But it might be a little rich. But better than being lean.
Matt
Matt
That gives me a good starting point.
Thanks!
Mahopac, NY
I think that the OEM's came with choke plates and smaller needle and seats ( high pop off.) The bolt pattern might be different( like 38's) need a stock intake manifold.
And the mikuni have choke plates removed. Need aftermarket intake manifold.
I think. I dont think that there is much difference perfromance wise.
freestylegeek
waiting...
Grand Rapids, MI
I think the 'stock' 44's came with 115/135/2.0/115g
I'm at 130/110/2.0/80g and it's running the SAME as when it had 120/110/2.0/95g.
I think I might have annother problem somewhere...I just don't know where.
Paul will be calling me back this afternoon I think.
If your carbs are 'stockers' 120/100/2.0/95g should get you in the ballpark (I think).
