Freestyle Jetmaniac / TriXstar finished
Hallo, i dont had the time to finish my 66e/951build:-((((
Now it is a 62t 90mm bigbore with new jetmaniac crank. Bought many other parts from Jetmaniac : Magpumpe, midschaft , steering/throttlecable; aircleaners, starter, bendix,startstop..........
Is a very good seller!!!!!
Hull is 2012 carbontrixstar S wirh new inner design and adjustable footholds. At moment engine runs wits 38s and oem ignition.
Hope i can shot some pics from riding ski.........
See you, Andy
ImageUploadedByTapatalk1337501971.935916.jpgImageUploadedByTapatalk1337502059.879204.jpgImageUploadedByTapatalk1337502089.563087.jpgImageUploadedByTapatalk1337502108.767711.jpgImageUploadedByTapatalk1337502187.244459.jpgImageUploadedByTapatalk1337502215.820672.jpgImageUploadedByTapatalk1337502237.251696.jpgImageUploadedByTapatalk1337502258.113453.jpgImageUploadedByTapatalk1337502277.983891.jpg
My grandfather was born in Hamburg Germany and told me some cool stories about it. \
Your boat looks real nice and yes Jetmaniac is the top of food chain.
3rid
NL
Andy, Excellent work on the cylinder... glad to see someone doing it that way and pushing it forward ... well done.
Cylinder is 62t 760ccm. Outsided filled with carbodyputty. Then milled the transfer/boostports. Waxed the ports and filled inside with putty for making plugs. Removed plugs and putty outside and installed sleeves. Sandblasted outside, fixed plugs in ports. Filled cylinder outside with epoxy/ alu mix. Epoxy is the same hightemp resin we use for our carbonchamber......so temperature is not the problem but maybe vibrations:-((((((
Have to try it........
AndyImageUploadedByTapatalk1337717719.137902.jpgImageUploadedByTapatalk1337717743.502308.jpgImageUploadedByTapatalk1337717782.677024.jpgImageUploadedByTapatalk1337717842.577251.jpgImageUploadedByTapatalk1337717875.423104.jpgImageUploadedByTapatalk1337717907.717748.jpg
