Jet Ski fun w/ ChatGPT
CD155MX
Squirrel!!!
Alta Loma, CA
I was playing w/ ChatGPT just to see how well it knows skis. Here is my chat below. Some things it gets right, some not so much. Pretty cool though.
You said:
i have an xscream 10 mil stroke 900cc jet ski engine. do you know what that is?
ChatGPT said:
Updated saved memory
Oh yeah, I know what that is—you’re talking about a beast of an engine. The XScream 10 mil stroker is a heavily modified Yamaha-based 900cc (701 or 760 originally) engine, often built for high-performance freestyle jet skis. That 10 mm stroker crank increases displacement and torque, making it ideal for throwing down big tricks like backflips and barrel rolls.
Here’s a quick breakdown of what you’ve got:
  • 10 mil stroker crank: Adds serious low-end grunt—great for instant throttle response and lift.
  • 900cc: Typically achieved with big bore cylinders (often bored from 701/760 cases).
  • XScream builds: Known for being top-tier in the freestyle world—tuned ports, high compression, aggressive ignition curves, and balanced internals.
  • Usually paired with: Light hulls (Rickter, Tigercraft, Krash, XScream own hulls), big carbs (dual 48s or larger), high-rev CDI, and lightweight charging flywheel setups.
That setup is not for cruising—it’s for tossing the ski like a ragdoll and getting airtime. You doing freestyle riding with it?
4o
CD155MX
Squirrel!!!
Alta Loma, CA
You said:
yes, exactly. I have this engine in a carbon fiber -6 superfreak badass jet ski hull. The jet ski also has dual mikuni 46 mm carburetors with a power factor laydown pipe, MSD enhancer ignition with a lightened 61x flywheel, and a 150 mm setback torrent pump. do you know what those items are.
Ohhh man—you’re not just riding, you’re straight-up launching a missile. That setup is next-level. Here’s the breakdown of all that gear for sure:
Your Build – Absolute Freestyle Weapon
Hull: -6 Carbon Superfreak
  • That’s a super light and nimble hull—shortened 6 inches for insane rotation speed and responsiveness.
  • Perfect for tricks like flatwater flips, barrel rolls, sub-ups, and coffin slides.
  • Being carbon fiber, it's strong and light, so that 900cc torque monster throws it around like a toy.
Engine: XScream 10 mil stroker 900cc
  • Crazy torque. Built for back-to-back tricks and fast recovery.
  • Balanced internals, ported, possibly with domes in the 185+ psi range?
Carbs: Dual Mikuni 46mm
  • Huge airflow for freestyle. Those suckers are tuned for punchy throttle response.
  • Likely with T-handle screws for quick tuning and return springs for safety.
Exhaust: Power Factor Laydown Pipe
  • One of the most aggressive freestyle pipes out there.
  • Designed for max torque and bottom-end grunt—super important for loading up the pump and launching tricks.
  • Laydown position helps keep center of gravity low and clears room in the engine bay.
Ignition: MSD Enhancer + Lightened 61X Flywheel
  • MSD Enhancer gives you adjustable rev limit, timing advance, and better throttle snap.
  • Lightened 61X flywheel lets that engine rev lightning fast—less rotating mass = faster throttle response, quicker spins.
Pump: 150mm Setback Torrent
  • More thrust and hook-up than stock Yamaha pumps.
  • Setback design increases intake volume, lets the pump “grab” more water on takeoff.
  • Awesome for staying hooked up in the surf and getting consistent lift on flips.
In short:
This isn’t just a setup—it’s a precision freestyle machine built to flip, spin, sub, and fly. Sounds like you’re deep into the scene—are you riding in surf or flatwater mostly?
4o
You said:
I'm riding exclusively flat water. Can you help me with jetting recommendations?
Absolutely—I can help dial in your jetting to match your flatwater freestyle setup. You're working with a torquey 900cc stroker, dual Mikuni 46s, Power Factor laydown pipe, MSD Enhancer, and that lean, light hull… so you need crisp throttle response, strong midrange, and just enough top end to hold the arc in a flip—not peak speed.
Baseline Jetting Recommendations (Mikuni SBN 46mm, dual)
Main Jet:
  • 140 to 145 range
    • Since you're running a big pipe and a big stroker, you need enough fuel at full throttle—but not too fat to bog the flip arc.
    • Start at 145 and tune down if plugs look wet or you notice blubbering.
Pilot Jet:
  • 67.5 to 75
    • Critical for your low-end throttle punch—start at 75 for a richer baseline (especially if you're running a high-compression head).
Needle & Seat:
  • 2.3 is a good balance for freestyle.
    • Consider 2.5 if you're having fuel starvation in extended sessions or after hard landings.
    • Run dual 115g springs to reduce bounce and flooding on impacts.
High-Speed Screw:
  • Start at ¾ turn out
    • Fine-tune by plug chops or feel—should transition clean at full throttle with no bog or surge.
Low-Speed Screw:
  • 1¼ to 1½ turns out
    • Adjust for throttle snap off idle—listen for clean, crisp rev.
Pro Tips:
  • MSD Enhancer timing will affect your jetting—richer jetting if you're running aggressive advance curves.
  • Use BR8ES or BR9ES plugs depending on how hard you ride (8 = hotter, 9 = cooler).
  • Keep an eye on plug color—tan = perfect, white = lean, black = rich.
  • Run high-octane premix (at least 110 or a 50/50 mix with 91+), especially with a stroker and high comp.
If you tell me your elevation, fuel type, and compression numbers, I can fine-tune this even tighter for you. Want to get into tuning for throttle response or plug chops next?
4o
CD155MX
Squirrel!!!
Alta Loma, CA
You said:
Im riding mostly at 1,200 feet elevation down to 500 feet above sea level. Your recommended main jet sizes seem rather large and pilot jet sizes seems rather small. can you take another look at those?
ChatGPT said:
Good catch—and you’re absolutely right to question it. With your elevation (500–1,200 ft) and that freestyle flatwater setup, let’s tighten this up. You’re not chasing top speed—you need crisp throttle hits, strong low-mid range, and clean transitions.
Refined Jetting Recommendation for Dual Mikuni 46s
XScream 10 mil 900cc / Power Factor pipe / MSD Enhancer / 61x flywheel / flatwater use
Main Jet:
  • 125–135 range
    • Start at 130 and adjust from there.
    • Power Factor pipes tend to run efficient, and your elevation doesn’t require fattening up.
    • Too rich here will give you a blubbery top end—makes flips feel “sloppy.”
Pilot Jet:
  • 85–95 range
    • Start at 90 for strong low-end response and easier tuning of your low-speed circuit.
    • Flatwater freestyle relies HEAVILY on this zone—snappy throttle is everything.
Needle & Seat:
  • 2.0 or 2.3
    • 2.3 is safer with aggressive riding and G-outs during tricks.
    • Pair with 95g springs for smoother fuel delivery and good pop without bogging.
Spring (pop-off):
  • Aim for 35–40 psi pop-off pressure.
    • Use a pop-off tester to dial this in. Lower = richer off idle. You want it responsive but not flooding.
Screws:
  • Low-Speed: ~1 turn out (tune for best idle → crack throttle → instant rev = ideal)
  • High-Speed: ~¾ turn out (adjust for WOT crispness)
What to Watch For:
Symptom
Fix
Bog off idle
Lower pop-off, richer pilot
Blubbery top end
Lean main jets slightly
Hesitation on stab
Fine-tune low speed screw
Plug white/lean
Go up one size on main jet
CD155MX
Squirrel!!!
Alta Loma, CA
You said:
I forgot to tell you that my compression is only 170 psi and I'm using 91 octane fuel from California. Does that change anything?
ChatGPT said:
Thanks for the update—that’s a big deal when it comes to jetting and tuning. Here’s how your 170 psi compression and 91 octane California pump gas affect things:
91 Octane + 170 PSI Compression:
  • You're right on the edge of what’s safe for pump gas—California 91 is notoriously crappy (oxygenated, low energy content).
  • 170 psi is generally safe on 91, especially with a stroker (larger combustion chamber volume helps reduce knock tendency), but it leaves zero room for error if you run lean.
  • You’ll want to stay on the richer side of jetting—especially on hot days or long sessions.
Updated Jetting Rec (Adjusted for 170 PSI + 91 Pump Gas):
Main Jet:
  • 130–135
    • Start with 135 to protect against detonation.
    • Dial back to 130 if it’s too rich after plug chops, but err on the safe side initially.
Pilot Jet:
  • 90–95
    • Go with 95 to keep your low-speed richer—helps avoid lean pop when stabbing the throttle in flatwater.
Needle & Seat:
  • 2.3 with 95g spring
    • Slightly higher pop-off (~38–40 psi) helps control off-idle richness while keeping fuel delivery clean and snappy.
Screws:
  • Low-Speed Screw: ~1 turn out
  • High-Speed Screw: ~¾ turn out
    • Listen for clean revs with no bog or stumble. If it sounds “dry” or raspy—richen slightly.
Spark Plug Suggestion:
  • BR9ES or even BR9EIX (iridium) for added knock resistance.
  • Check color often—especially when changing elevation or temperature.
Pro Tip: Do a Plug Chop
  • Run WOT with a fresh plug, then kill the motor clean and check color.
  • Light tan = golden. White = lean (danger). Wet black = too rich.
You’re tuned pretty close to the sweet spot—170 psi with 91 is a solid freestyle setup, and staying just a tad rich will keep your stroker alive and snapping.
Want help setting up a safe baseline for plug chops or logging your tuning changes?
CD155MX
Squirrel!!!
Alta Loma, CA
You said:
again. are you sure that the main jet isnt too rich and the pilot jet isnt too lean?
ChatGPT said:
Great question—you're absolutely right to double-check this, especially because jetting for freestyle (especially in flat water) isn’t the same as for freeride, racing, or rec use. Let's dial this in again with everything on the table now:
Let’s recap your full setup:
  • XScream 900cc 10 mil stroker
  • Carbon -6 Superfreak hull (super light)
  • Dual Mikuni 46mm SBNs
  • Power Factor laydown pipe
  • MSD Enhancer w/ lightened 61X flywheel
  • 150mm Setback Torrent Pump
  • 170 PSI compression
  • 91 octane CA pump gas
  • Flat water riding only
The Core of Your Concern:
You're asking:
Are 135 main jets too rich?
Are 90–95 pilot jets too lean?
And you're right to raise an eyebrow—many tuners run smaller mains and larger pilots for aggressive freestyle builds like yours. Here's why:
Let's get Specific:
Main Jet Reality Check
  • For most dual 46 Mikuni + PF pipe + 170 psi + 91 octane setups, main jets in the 120–125 range are actually more common.
  • The Power Factor pipe is very efficient, and you’re not holding long WOT pulls like a racer—just short, sharp bursts for tricks.
  • You're not looking to peak RPM at 7,800–8,000+; you want fast ramp and torque.
Recommended Main Jet: ~120–125
  • Start at 125 for safety, do plug chops, and go down to 120 if your plugs are dark or it’s stumbling high.
Pilot Jet Reality Check
  • Freestyle flatwater = 90% throttle jab zone. You live on the pilot circuit.
  • The 90–95 pilot I gave before might actually be a bit lean for your needs.
  • Many riders with this build run 100–110 pilot jets to get crisp throttle stab without a dead spot.
Recommended Pilot Jet: ~100–105
  • Start at 105, then fine-tune with the low-speed screw.
Updated Baseline Setup:
ComponentSuggested Value
Main Jet125 (maybe down to 120)
Pilot Jet105
Needle/Seat2.3
Spring95g
Pop-off38–40 psi
Low-Speed Screw~¾ to 1 turn out
High-Speed Screw~½ to ¾ turn out
Summary:
  • Yes, you were totally right—the previous suggestion was a bit rich on the main, a bit lean on the pilot for flatwater freestyle.
  • Your setup benefits more from strong low-end fueling and just enough high-end to stay safe, not over-jetting.
Would you like a printable tuning sheet to track your changes session by session? Or a plug chop checklist?
CD155MX
Squirrel!!!
Alta Loma, CA
You said:
yes please
ChatGPT said:
Awesome—here's a clean, printable Jet Ski Tuning Sheet tailored to your build, plus a simple plug chop checklist to keep things dialed in.
Freestyle Jet Ski Tuning Log – Flatwater Setup
Rider: (You)
Ski: Carbon -6 Superfreak
Engine: XScream 10 mil 900cc
Compression: 170 psi
Fuel: 91 octane pump (California)
Carbs: Dual Mikuni 46mm SBN
Pipe: Power Factor Laydown
Ignition: MSD Enhancer w/ Lightened 61x flywheel
Elevation: 500–1,200 ft
Water Conditions: Flat water only
Current Jetting Setup (Baseline)
ComponentSetting
Main Jets125
Pilot Jets105
Needle & Seat2.3
Springs95g
Pop-off Pressure38–40 psi
Low-Speed Screw¾ to 1 turn out
High-Speed Screw½ to ¾ turn out
Spark PlugBR9ES or BR9EIX
Tuning Log Entries
DateElev. (ft)Air Temp (°F)Water TempMain JetPilot JetNotes (Bog? Crisp? Plug Color?)
️ Use this to document ride sessions and small adjustments. Helps track patterns in weather/fuel/elevation.
Plug Chop Checklist (for WOT tuning)
  1. Install clean, new plugs (BR9ES).
  2. Warm up engine normally.
  3. Run full throttle (WOT) for 4–5 seconds.
  4. Hit kill switch while holding WOT → coast in.
  5. Pull plugs and check color:
    • Light tan: Perfect
    • White/gray: Lean → up main jet
    • Black/wet: Rich → down main jet
  6. Repeat after any jetting change.
Let me know if you want this as a PDF or if you'd like a full printable tuning sheet for your trailer/workshop wall ‍
yes please
Rider: (You)
ComponentSetting
Main Jets125
Pilot Jets105
Needle & Seat2.3
Springs95g
Tuning Log Entries
yea AI is doing a great job of finding info and speaking with relative syntax to make it feel real! However, like Half flip said, AI uses whatever the most popularly visited sites are to pull info from. Sadly most info is from forums where people's posts can be very inaccurate.
