61x (701) is the regular cylinders which superjet use the std size is 81mm
the max size is 83.5mm without any risk and 84mm is the real max size
62t (701)is the regular cylinders which blaster use the std size is 81mm
62t(760) is the cylinders which blaster use the max size without any risk is 84.5mm and 85mm the real max size
64x(760)???????? i don't know where yamaha installed but the max size without any risk is 85.5mm and the real max size is 86mm
all this is correct ????
