is this the max bore size ???
iptamenos
Flipping Around !!!
Greece
61x (701) is the regular cylinders which superjet use the std size is 81mm
the max size is 83.5mm without any risk and 84mm is the real max size
62t (701)is the regular cylinders which blaster use the std size is 81mm
62t(760) is the cylinders which blaster use the max size without any risk is 84.5mm and 85mm the real max size
64x(760)???????? i don't know where yamaha installed but the max size without any risk is 85.5mm and the real max size is 86mm
all this is correct ????
A stock 61X can go to 84, but it's getting thin.
GroupK says 84.5 is still safe.
I've known people to run them at 85mm.
Keep in mind that a properly set up engine with a good port job will give you more power than a slightly higher displacement engine that's not set up so well.
I certainly wouldn't buy big bore sleeves, go through all the trouble and expense of installing and porting them, and then go immediately to the max bore. That's just stupid.
LIVE2RIDE Powersports
Live & Die 2 Ride
WorldWide
I may just try a ported 745 for this year. Will i feel much over my ported 710?
yamanube
This Is The Way
Staff member
Mandalor
What are you going to use for a Piston at 86.5mm?
Riva is 86mm max.
Wiseco is 86mm max.
Kawasaki Wiseco sm.pin big bore is 85.5mm max.
Unless I am mistaken 745cc would be an 83.5mm piston wouldn't it?
I have run a 64x motor with 86mm pistons. Worked well, till the crank let go.
Riva is 86mm max.
Wiseco is 86mm max.
At stock stroke 83.5 would make 745....unless Chuck has something up his sleeve???
No.
I was responding to your question "the 64x 760 cc cylinder have different sleeves compare to 62t 760cc????"
