After a very short WOT run my 96 RN quit me and when I finally got it started again and limped back to shore the starter sounded like a no compression situation, the speed it cranks when you're pumping water out of the cylinders. Put a compression gauge on it and got 30psi in the first cylinder and 160 in the second cylinder. I think the gauge wasn't tight on the first cylinder. Took the head off, saw there were multiple different kinds of bolts on it. Its a riva head, unsure of the dome size but they're roughly 50mm across inside. The 2nd picture down shows some gunk I saw on the stud below the cylinder.
