A 14 AH battery is usually quite sufficient to crank a SJ. Might you have very high compression ? Is your t/l ignition programmed to have no more than 20 deg., preferably 15 at cranking speed? I suggest - for a test- take the cables off your battery and using automotive type jumper cables hook them up to a different battery like a car. Also, a standard load test for a battery is: Voltage should not drop below 10.5 volt while cranking for 15 seconds. That test is of course not possible if your bendix disengages. To test for bad ground cable, run a temp. cable from bat. to the engine (head, intake or front cover, whatever is easy to reach.)
