sjetrider
- in the 615 (Nashville)
title says it? :biggthumpup:
sure..almost anythings paintable.. but its flexible so it will crack if its pushed on or stretched..
if you can clean up the area of the 5200 where you are trying to paint and then reapply new after its painted
what are you trying to paint?
5200 is over rated in a lot of aspects, IMHO.
i agree... i swore by it during my build... but i dont think its half as strong as people crack it up to be.
it still silicone. it peels right off my tubbies. when i paint my ski ill remove the excess and glass them on the right way.
epoxy resin FTW
You gotta prep right for 5200. It is strong as hell. It has it's place in life, but not in all places. Yeah it's messy but you can make it look good by smoothing it with acetone. It will thin with acetone as well.
Oz
Yeah a lot of comments by people who have no idea of how strong 5200 is ,I will tell you how strong it is though.Back when I worked at the Mastercraft dealership we had the big January boat show coming up.One of the comp ski boats went up on a big overhead rack where you could walk up under the boat.The owner got the bright idea that the fins under the boat needed to be polished.They are through bolted with 5/16 stainless screws and a layer of 5200 is put on them before the are installed.We removed all the screws and started to remove the fins.It ended up taking three people to remove the fins,one to crawl up under the boat and hold a piece of 4x4 post against the fin,one on the outside of the boat to hold the other end of the post and one to whack the post with a 25 lb sledgehammer,thats how strong 5200 is!
