schicks
Karma Enforcer
- West Michigan
I recently bought a FX-1 and it runs great most of the time. Once in awhile when I hit the green start button, nothing happens. It doesn't crank, click, nothing. At first I thought the plugs that run from the start/stop switch to the CDI box were faulty, but they look good, I even put some dielectric grease in them. This past time when I tried starting it before I put the ski in the water it did it again. Eventually I got the engine to turn, but it kept cranking and wouldn't start then it sounded like something broke inside the casing where the fly wheel and stator is located. I stopped and did not try to start it anymore. I was going to work on it today and decided that before I started working on it I would see if it starts. The engine fired right up as soon as i pressed the start button (didn't even prime it). So I'm not sure where to go from here and am looking for any suggestions. I don't want to take it to Lake Michigan until this problem is resolved so I want to get it fixed asap.
