adet16v
No like winter
- Montgomery County PA
I know a few of you have used this to paint your skis.
I am looking to paint my sn and rn this year.
I am planning on using Interlux Perfection (top deck) paint.
Today I called the manufacturer to ask for a recommendation from them on a primer and other prep tricks. Basically the only good information I got from the manufacturer was that I needed to use a 2 part primer with this paint.
The representative I spoke to instructed me under NO circumstances should I spray Perfection using a gun due to "very harmful chemicals"... he told me it should only be rolled on. I asked if he could recommend a cartridge for a respirator and he said that he could not and repeated that "under no circumstances should it be sprayed":thumbsdown:
From their website "Method of Application" it reads: Brush / Conventional Spray / Roller
So I know the guy is full of poop.
Can some of you who have used this stuff give me some tips on prep/primer/use sealer/how many coats/curing time/wet sanding etc. etc.
