Installing Pole Spring On Xscream Pole
So.... Last night I was attempting to install a new xscream pole on a SXR, and I cannot get a pole spring to fit in there for the life of me! The ski had an aftermarket spring which I slightly modified to try to get it to fit, but still no dice. I tried fitting the stock spring in there, and then somehow managed to bend the bolt during the whole ordeal. I also tried to fit the 2 stock springs for a SJ, but no luck either.
Any ideas? Even better, and pictures?
You have to drill a hole in the pole approx in the middle section at the very bottom as shown in first pic.Then the long leg goes downward into pole bracket or a plate added if not using a pole bracket like on a freak. This is a Blowsion HD spring from @JetManiac.
