air blair
you are the reason
- thumb, mich again
Scuff surface with sand paper. Acetone clean both surfaces. Buy Ufo mounts from JetManiac.
jam clay in both sides. Adjust level off hull with clay. Keeps thread from getting resin in them. Mix up some epoxy or I did ve resin with glass spheres, cabosil, and 1/2 inch glass chop. Can add pigment for coloring.
lay Ufos nut up and squish into the peanut butter consistency putty. Cut some thin glass and put a hole in middle. Use the glass to smooth the putty into a tapered to nut surface. Once you have that done
apply resin as you would to regular glass and finish smoothing it over.
to finish it off after it cures sand off flush and run a tap down by hand to remove clay. Hope this helps someone. That's the purpose of this share. Have fun.
