Mile9c1
X-H2O.com
- Grand Rapids, MI
All the OEM bottoms are SMC... you wish they were chopper gun! :skull2:
I think it varies from year to year. I think the tops and hoods of squares are SMC. Bottoms are glass..........I think. The SMC is the brown stuff.
and lastly:.
Whitney and Britney
:Banane26: :wave: :wave: :Banane19: :Banane25:
Here's inside my waterdawg 65lb hull w/hood prepreg hull (top), compared to the wf 100lb. hull (bottom)
[/PIE]Is that 5200 that holds all of the hardware and engine plate assembly? Does he use it also to bond the hull and deck together?
Your comparing a pre-preg hull vs a hand layed hull. Of course one is gonna be lighter than the other and cost quite a bit more. Just like comparing carbon vs a glass hull:dunno:
Plexis is used for bonding, 5200 for sealing the edges. Its only $1000-1500 more than a your glass hull, (I'm sorry I don't know the exact cost of your hull and hood), 35lbs lighter makes a very nice performance improvement, easily $1-1.5k worth. If im gonna spend money on an aftermarket hull it needs to have an advantage over a reinforced oem hull. 1. Personally I ride flatwater and need the lighter hull to get me out of the water, I don't need a heavily reinforced hull 2. this hull allows me to run my 66e motor. 3. it doesnt' look like a superjet. I mainly posted the pic to prove that there are different levels of Jeff's hull and I feel the quality of prepreg fiberglass is superior over wet layed up hulls.
I agree that you guys are both competent hull builders, just each buyer has a different goals and wants in a hull. You should respect the judgement and choices of each buyer, not bash them.
See you guys in daytona, that is if my pvc exhaust doesnt' fail.
Hey Tom, not bashing here!! just making some comparisons. I'm glad you like your hull and want the ultimate in lightweight+horsepower. I hope you get to test your hull in the surf and put it thru it's paces. Maybe you should let Pete (Pancaker) use it for a few months!:Banane01:
Maybe you didn't understand my quote, Its not a surf hull, it was built to light and get me out of the water on our choppy wind waves. If I was building a surf hull, jeff could have gone thicker on the prepreg and made it more durable (but of course, it'd still be lighter). My current hull would break in Pete conditions (Pete can punish a hull, no doubt) , but it would perform better and last longer than a lightweight "wet laid" hull. I was told Pancaker's hull was around 125-130lb hull/hood, over double the weight of mine. His wont break, but it'll never perform like a lightweight hull (or any different than a heavily reinforced oem hull) I perfer the feel of a lightweight hull to any other hull and since I don't surf ride it fits my need. You filled pete's need by putting an extra 60lbs of resin and cloth in it. Different needs for different customers.I hope you get to test your hull in the surf and put it thru it's paces. Maybe you should let Pete (Pancaker) use it for a few months!:Banane01:
IMO,There is less technology in a wet laid hull than an oem hull. The only advantage i can see is you can lay it up thick for durability.
I still appreciate that you build parts for our sport, don't get me wrong. Everytime wf and wd post pics of their product, it helps the buyer decide which way to go.
Steve do you have a freepass for the entire weekend in daytona or just parol for a day ?
Hope you have a full freepass weekend.
