What is the best way to get the impeller out of the pump? If anyone in the Oceanside Ca area is able to help, that would also be awsome. I have the pump loose from the ski. Should I put the screws back in and remount the pump and get it loose while its coupled to the motor? Im thinking that might not be a good idea cause of the bearings and seals going through the hull...dont wanna damage those or the motor. Any thoughts would be appreciated. Thanks. -chris
