- Fort Worth
i rebuilt my pump with a new bearing kit from jetmaniac. when i took the old impeller off, it had the 2 seals, then a spacer then the impeller. when i put it all back together, i tried to install the spacer under the impeller and it makes the shaft and whole assembly bind up. but when i leave it out, the impeller bottoms out on the threads and there is literally not enough space to slide a piece of notebook paper in between the stator veins and the impeller. BUT the impeller doesn't touch the veins. spins freely. is this ok to run?
