i want to relocate my electric bilge outlet
hallstudio
learn to ride then trick!
matietta ga
the last owner tryed to hide the bilge outlet under the edge of the hood (1991 SUPERJET) and i would like to have it exet out the side so i can see it. anyone know the best way or easy way to plug the old hole.
Gunter83
Trainwreck
Greenville, SC
I would glass one side fill hole with epoxy or stuff some glass in there and resin it up good then do the same with the outside/inside. Sand/paint good to go.
hallstudio
matietta ga
was hopping for rubber plug or somthing. what you recomend sounds like work......This is America we dont work anymore...mabey there is a goverment program that will fix my old hole for me. LOL just kidding.
hallstudio
matietta ga
Dam...my first post and I already look like an idiot. The current hole is located in-between the hood seal and the edge of the hood. It can hardly be seen. It’s on top and in no direct line of water travel. This is the only reason I thought a rubber plug might work.
hallstudio
matietta ga
duct tape:fing02:
is it hard to use? where do i get it from and does it come in cool colors?
Just kidding
i guess i need to enjoy it over the summer then make a nice winter project with a new paint job and relocated bilge exit. thanks for the help.
Duct Tape:arms:
rasper99
Freighter wake hunter
Portland, OR
For this season:
Cut the hose on the inside to about an inch then use a plug and a hose clamp. As long as it's already hidden and keeps the water out it's good enough for this season's riding.
Then as you say do it right this winter.
yamanube
This Is The Way
Staff member
Mandalor
Yep, a rubber body plug glued in place would seal it right up. Don't worry about looking stupid, some people will go out of their way to help you do that.
