How to shorten stock sn pole
Phill
v Check out Little Matt_E
Kennewick, WA
If you try to use the stock SN bracket, the pole will not go up all the way. Only about 2/3 of what it used to due to the difference of the angle of the deck between the SN & RN. I have seen several friends struggle with various methods of overcoming this problem. I recently put a X-Metal pole on the wife's ski and found that Pat makes one of his nice SS brackets & backing plate that works killer on the SN. You will get full extension of the pole and a bullet proof bracket too. The hood hooks are built into the bracket, you only have to relocate the hood hooks farther apart on the hood. This will make your install a lot easier and everything works well.
Check it out at http://www.xmetalworks.com/prod.html you will have to call for Pat and ask specifically for the SN version of the bracket.
I was told that x-metal does not make a bracket for the RN pole on a SN anymore.
When did you get your bracket?
